| | | Forums66 Topics128,042 Posts1,055,515 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Has anyone some experiance with poly-slide / multi leave spring liner that goes between the leave springs?
How much different is the ride quality, are there different qualities?
Where can I get them?
Thanks | | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | Speedway Motors has it in a couple of different widths. I have not personally used it, but have heard good things about it from others. It is what I will use, when I finally get to that part of my build. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've used it,and am very pleased with the ride quality. I will admit, my truuck does rid a bit rough, but I am still running the stock springs with all the leaves inact and also have the 3/4 ton rear spring option. The spring action is very smooth, though.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | I use it and really noticed a difference once installed. It was way better then grease, its also a lot quieter now. Joe | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | How much does it add to the thickness of the spring? Denny G
Denny G Sandwich, IL
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | Maybe .030" to .060" for each liner installed. I didn't go measure it, but I could if you really want to know. It wasn't much. Joe | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
