5 members (frogfarmer, baldeagle, Otto Skorzeny, tclederman, Rusty Heaps), 62 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#495967 01/21/2009 8:57 PM
could someone please tell me what engines ARE compatible with my 235 mounts, trans (manual) etc.? I am going to replace my 235 and cant find one, but have found other 50's engines on craigslist etc.. I jsut dont know what engines would slide in w/ minimal hsadache. so 200? 260? etc. can I unbolt and rebolt these up to me trand and mounts?
thanks in advance,
56 stepside 3/4 ton longbed
If you are asking about this for a 56 truck than only a 1955-59 235 or 261 will bolt right in.
My Blog
so 261 will bolt right in... to my trans / bellhousing / motor mounts? no changes at all??
A 1955-59 truck with a six mounts on the very front sides and on the bellhousing.
A 1955-59 261 has spots for the front side mounts and the same bellhousing bolt pattern as a 235.
If you want to adapt to center side mounts than any 1960-62 261 would work also.
My Blog
Don't forget that the V8 came stock in these trucks. Direct bolt in with a v8 bell housing. But, I assume you want to keep the I6.
