| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | could someone please tell me what engines ARE compatible with my 235 mounts, trans (manual) etc.? I am going to replace my 235 and cant find one, but have found other 50's engines on craigslist etc.. I jsut dont know what engines would slide in w/ minimal hsadache. so 200? 260? etc. can I unbolt and rebolt these up to me trand and mounts? thanks in advance,
56 stepside 3/4 ton longbed
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you are asking about this for a 56 truck than only a 1955-59 235 or 261 will bolt right in.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | so 261 will bolt right in... to my trans / bellhousing / motor mounts? no changes at all??
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1955-59 truck with a six mounts on the very front sides and on the bellhousing. A 1955-59 261 has spots for the front side mounts and the same bellhousing bolt pattern as a 235. If you want to adapt to center side mounts than any 1960-62 261 would work also.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Don't forget that the V8 came stock in these trucks. Direct bolt in with a v8 bell housing. But, I assume you want to keep the I6. | | |
