2 members (Guitplayer, MickeyP), 70 guests, and 2 robots.
Topics128,021
Posts1,055,356
Members48,420
#495207 01/19/2009 9:47 PM
Has anyone some experiance with poly-slide / multi leave spring liner that goes between the leave springs?
How much different is the ride quality, are there different qualities?
Where can I get them?
Speedway Motors has it in a couple of different widths. I have not personally used it, but have heard good things about it from others. It is what I will use, when I finally get to that part of my build.
http://community.webshots.com/user/49chevyman?vhost=community
"The only people who do not make mistakes, are people who do not do anything."
I've used it,and am very pleased with the ride quality. I will admit, my truuck does rid a bit rough, but I am still running the stock springs with all the leaves inact and also have the 3/4 ton rear spring option. The spring action is very smooth, though.
Bill Burmeister
I use it and really noticed a difference once installed. It was way better then grease, its also a lot quieter now. Joe
How much does it add to the thickness of the spring?
Denny G
Denny G
Sandwich, IL
Maybe .030" to .060" for each liner installed. I didn't go measure it, but I could if you really want to know. It wasn't much. Joe
tks
DG
Denny G
Sandwich, IL
