1 members (baldeagle), 56 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#49581 08/27/2005 5:42 PM
There are a lot of tune up tasks, especially adjusting valve clearances, that require turning engine be hand. I have always used a remote starter switch for my solenoid starter engines.what is the best way to turn the engine by hand for foot operated starter engines? Thanks everyone.
My rule of life: You can have anything you want; you just can't have everything you want.
#49582 08/27/2005 5:56 PM
Riding in the Passing Lane
Grab the fan blade with one hand & the belt with the other & pull. smile
1972 Chevy c10 Cheyenne Super
#49583 08/27/2005 6:49 PM
Or get a helper to turn the crank on the front for you.
That's what I usually do.
#49584 08/27/2005 8:38 PM
Put the vehicle in high gear, and gently roll it forward or back. Be sure to disconnect the coil wire, or ground out the points, so you won't run over yourself if a cylinder fires.
#49585 08/27/2005 8:42 PM
mine has the foot switch too and i can just pry a screwdriver behind the lever on the starter from under the hood and make the starter engage. again, make sure to leave the ignition switch off or take out the coil wire, etc.
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
