4 members (Brian Moore, walter74, J Lucas, Jims46), 62 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#493570 01/15/2009 5:04 PM
ok so im a computer idiot i will try one more time then i will seek help my web space
philip t #493575 01/15/2009 5:06 PM
i dont get it my web space
philip t #493634 01/15/2009 8:15 PM
the second link works
philip t #493645 01/15/2009 8:56 PM
Socket Breaker
Socket Breaker
That is a sharp looking truck.
-W
philip t #493663 01/15/2009 9:40 PM
thanks its been a lot of work the body work is far from perfect
but i did it all myself the mechanics on the other hand are more my strong suit the engine is a 60 model 235 i added a hei from a 250 and langdons holly webber kit. it sure runs good i cant wait to drive it. the headlights and hood will go on this weekend then
i need to tie up the loose ends. philip
philip t #493759 01/16/2009 12:31 AM
Looking good!!! thumbs_up
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
Cannonball #493933 01/16/2009 11:02 AM
Way ta go Phil. Looks great !
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #494355 01/17/2009 2:14 PM
I'm jealous,
Looks great! I cant wait to get started on mine.
JeffL #494663 01/18/2009 6:21 AM
Big Bolt Forum Co-moderator
Pretty cool pictures. On my computer I had to open and back click but it was well worth looking. What did you paint the frame with? What about the sound deadening material? Is it a generic material from a parts store? My truck had a felt pad in it, but it was a moisture holder if you ask me. Does that dog in the picture play the harmonica?
1948 Chevy 2-Ton
Super55 #495116 01/19/2009 3:13 PM
the frame is painted with acrylic enamel the paint store put a paste in to make it semi gloss. i used the foil covered bubble wrap stuff from lowes to insulate the cab i also put the insulated firewall cover from jim carters. the fire wall cover is great
but a real bear to install. the blue heelers name is jake he runs things around here were just here to feed him. philip
philip t #495626 01/20/2009 10:53 PM
Apprentice
Apprentice
That is a FINE looking truck!! I am working my 46 1.5 ton and wasnt sure were to find the tires and a motor to fit the truck. Any information you can pass along would be greatly appreciated. Hope you'll post a video of the the truck running and driving.
EMS is my life. But I have found my TRUE PASSION OLD TRUCKS...
Bubba the Emt #495683 01/21/2009 1:12 AM
im going to buy two front tires for now. my local truck tractor tire dealer can get them. you can also order them from an oriental
company called simex but i at least want an American name on mine.
i put a 1960 235 in this truck i found it in a junk yard for 100.00
with the trans. it cost me 1700.00 to rebuild it with new pistons
bored crank ground head done and new cam. these motors arent that hard to find you just do not find them in the big salvage yards that deal in late models. you find them in junk yards or from someone that has one.
philip t #495870 01/21/2009 1:36 PM
philip,
you truck is awesome. very nice.
just curious on these big trucks, does someone make the hood, fenders, windows, etc, like they do for the smaller 1/2 ton trucks ?
have fun.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
RATRODKING #495906 01/21/2009 4:47 PM
i think the hood and windows are the same as the 1/2 ton tho only real difference in the cab is the fenders and running boards.
the cab is not bigger it just sits on a higher chassis.
philip t #495911 01/21/2009 5:17 PM
thanks for the info.
i was just curious.
leonard
RATRODKING #495978 01/21/2009 9:27 PM
Apprentice
Apprentice
Thank you philip t. Thats helps alot.
