| | | Forums66 Topics128,023 Posts1,055,366 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49563 08/26/2005 10:21 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I'm putting a 292 and 4 SPD in a 47AD. I planned on getting Chevy Duty's crossmember and Langdon's motor mounts. I saw a thread on Chevy Duty which indicated a crossmember isn't necessary, even with a non torque-tube rear end? Is this possible? It sure would save me some trouble and a little bit of money, even though it doesn't make a lick of sense.
jay
Your lack of preparation is not my emergency
#49564 08/27/2005 1:00 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you sidemount the motor and use a bellhousing that mounts to the existing crossmember you don't need a transmission crossmember.
However, there is no stock bellhousing that will bolt to a 292 and the existing crossmember, so either you have to make custom mounts or replace the bellhousing crossmember with a '54 or '55 1st crossmember to support a V-8 or later six type bellhousing.
I think I'd order the Chevy Duty or someone else's crossmember...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#49565 08/27/2005 1:02 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Of course after advising buying the Chevy Duty crossmember I should admit that I have a '54 Chevy frame I'm parting out, and I plan to keep the bellhousing crossmember to use in my '51....
#49566 08/27/2005 4:22 AM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | Thanks. After a quick eyeball, it didn't look like it would mount to the old crossmember. Maybe I'll just leave it in for strength, if it'll fit.
jay
