4 members (Raymond HAYWOOD, Hush, Shaffer's1950, Cosmo), 216 guests, and 4 robots.
Topics128,088
Posts1,055,993
Members48,430
#49542 08/26/2005 5:58 PM
I need a speedometer gear that drives the speedo cable for a saginaw 4-spd. The one in there now is ALL plastic and the teeth are worn down , not stripped. If it were steel I'd get the gear from Patricks, but it is not. Any help locating one would be appreciated. Thanks. Old Pilot
#49543 08/27/2005 2:02 AM
Do a web search for Camaro Parts,you will find what you need.
#49544 08/27/2005 3:03 PM
The speedo driven gears are usually dealer items, but they're getting harder and harder to find. They're color coded for the number of teeth, so if you can take the old one into a dealer and talk to an old-timer in the parts department, he/she might be able to get you what you need.
But beware: if the teeth are gone on the driven gear, they're probably gone on the drive gear. On a Saginaw (as I recall) that's on the main output shaft and is the last part to come out during disassembly.
If all else fails, this company may be able to help you out.
Good luck with it,
