1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Does anyone know the NAPA (or other supplier) part numbers for inner and outer front wheel bearing sets for a 1954/55 350 series GMC COE?
Tim
3B Offline
Hy tcledreman, factory p/n inner 7450335 = hyatt C125298WA = bower 25583 - 25519, factory p/n outer 7450336 = hyatt A1342242 = bower 15103S -15243 , hope that helps.
3B Offline
Hy again tclederman, I did some more research and came up with the Napa numbers BRG BR25583 @ $59.99 , BRG BR25519 @ $26.49 , BRG15103S @ $23.49 , BRG BR15243 @ $12.49 , hope that helps
3B the Hyatt # C125298WA is the same as My 56 inner bearing how did you find the cross reference numbers for these? I had no luck with three different bearing houses and Napa good find. I am leaving a link to a picture of the bearings inner seal and spindle from my 56. Note the inner bearing has the seal surface built in this was the biggest road block I hit trying to find replacements.
http://good-times.webshots.com/photo/2442573050096773078zfpYGN
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
3B,
Thanks. I will check out NAPA and others. I should have asked for the inner seal number, too; but, I should be able to find that now.
Tim
3B Offline
Hy Hevyhauler, I'm a psychic, actually I have a master bearing interchange book, when I tried to look one of these up using the Hyatt numbers, nothing, so I used the original G.M. numbers and presto. I'm not saying that these are exactly the same, their just whats listed as interchangable.
Hy tclederman, the inner seal number I come up with is National p/n 6785, but my book only goes back to 1955
3B,
Thanks again. You have set me up very nicely. I have not yet purchased the truck - I did not know that larger trucks have roller bearings. My experience is limited to 1/2 ton 47-55 trucks, but that might change in about a month.
Tim
3B Offline
Hy guys, something I have noticed over the years, cabovers seem to have the heaviest duty components available, why I don't know.
3B,
You are right about these COE parts. It looks like a 1.5-2 ton COE uses the same bearings as used on the 2 ton SCB (School Bus Chassis). All other sizes from 1/2 ton to 1.5 ton use roller bearings.
Thanks again,
Tim
I hate to be so politically correct, but just for the record, there were no '47-'55 GMC 1 1/2 ton COE's. They were all 2 ton, & up. 15000lb. gvw '47-'55 Chevy 1 1/2 ton COE's, are very "Rare". Tim, have you found these wheel bearings in stock anywhere yet.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Spanky,
You are not being politically correct - you're correcting and educating, as usual. Thanks.
I will not be able to get GMC info until late Sunday (from our English-man friend), so I am guessing about GMC's from the Chevrolet Master Parts catalog information and the information provided by 3B.
The roller bearings parts are available from NAPA and can be obtain immediately or in a few days, at most. If the 350 GMC's use the roller bearings (I doubt it), I have those part numbers and those parts are also available.
Finding a military-style (or other style) tow-bar is the last piece of the puzzle in getting that COE from the west coast to NY.
Tim
I have 4 NOS Hyatt 125298W $40 ea. These are the inners.
E-mail me if interested [email protected]
F350 gmc should have three piece bearings B45 B46 BCA abour 200 per wheel
Tcleaderman,
If chevyb says he has them then they are the right ones.
He lives about 2 hours from me, I and I have bought a number of things from him.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
What years do these bearings work on. I have a 49 chevy 4400. It is not a COE
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
No, I'm pretty sure they are not the same.
It's been more than a year sense I installed Tim's front wheel bearings, but I think they are bigger/different than your 4400 wheel bearings.
Tim's COE is a good bit bigger and heavier than even a 2 ton Chevy, and you have a 1.5 ton which I believe has even smaller/different wheel bearings than the 2 ton.
All just guesses on my part..
A parts manual will let you know for sure.
Take your old bearings to NAPA and see if they can get them.
And or call "chevyb" and see if he has them in stock, he'll have a pretty good idea what you need just from your year and model number.
Grigg
---All pictures---
