2 members (TPR57C, baldeagle), 63 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#495084 01/19/2009 10:39 AM
Just a Tip for everyone,
NEVER POUR GAS DOWN A CARB TO TRY AN GET YOUR MOTOR TO START!
Got a call today, a bud of mine was messin with his 78 Silverado that wouldnt start in the 10 below zero weather we are havin and was givin the carb a little drizzle a gas outta a plastic pop bottle in an effort to get it to fire ...well it did ...backfired,lit the pop bottle on fire, he jerked back in responce to the backfire, spewin burnin gas onto his chest wich in turn lit him on fire melting his sweatshirt to his chest, luckily he had a bud there that grabbed a fire extinguisher an put him out.
He is currently in the hosp. with 2cnd & 3rd degree burns, to his chest an neck, BE CAREFUL FOLKS!
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #495249 01/19/2009 11:49 PM
jdl Offline
If you do put gas or starting fluid down the carb, DON'T DO ANYTHING UNTIL YOU PUT THE AIR CLEANER BACK ON! They serve not only the purpose of cleaning the incoming air of the engine, but also as a flame retarder in the event of a backfire in the carb. I never EVER start the engine without it on.
P.S. Tim, I hope your friend is okay and recovers 100%.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #495253 01/19/2009 11:57 PM
Wise words Jordan, I've been doing this to keep my engine 'lubed up' while it's in the garage. I tip a little gas down the carb,stick the filter on and let it 'gas up' for a minute....then kick the engine over.
That way I'm well away from any potential backfire etc.
Tim ...I hope your buddy recovers well too. Gas fires are real scary!
Jock.
More pix on Flickr.
jockbolter50 #495262 01/20/2009 12:17 AM
Leo Offline
Moderator
Moderator
In can happen real quick, safety is always first. I hope he will be OK.
Leo #495290 01/20/2009 1:13 AM
I use WD40 and starting fluid. a 1 second burst of WD40 followed by a quick 1/2 second blast of ether then crank, there is just enough propellant to get the engine to start without the dangers of gasoline.
Another thing to be wary of is hand choking the engine. I know a local mechanic who used to have his own diagnostic shop that almost lost his hand doing that. The engine backfired while he had his hand over the carb. He suffered severe burns and lost partial use of his hand.
Bill Burmeister
LONGBOX55 #495333 01/20/2009 2:23 AM
I use a blast of carb cleaner, and then I run around and get in the cab to hit the starter.
"Happiness equals reality minus expectations" - Tom Magliozzi
Jim Bow #495350 01/20/2009 3:02 AM
SMART jl,
i learned (don't ask how) to ALWAYS put the air filter cover back on b4 i turn that key. dang
Jim & Caroline
