1 members (Hotrod Lincoln),
126
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 36 Apprentice | | Apprentice Joined: Jan 2007 Posts: 36 | Does anyone know where I can find the packing/gasket material to rebuild the torque tube on the rear of the '35 transmission? I could only think of a large "O" Ring, but I don't think it would handle the stress of the movement. The old ones are very hard and brittle. Any suggestions please. Thanks | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Actually a rubber "O" ring which is grease resistent will work. I've used one successfully. Pretty inexpensive, too. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | felpro kit #ES72843. universal joint set. 1-cr5158 u-joint packing 4-729 universal ball collar gasket 1-cr18280 u joint ball collar 4-18290 u-joint retainer shim
chevy truck six 1935-56
i got mine from napa
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | If I was doing it, I would use the Felpro kit and substitute the "O" ring. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'm not getting into the pros and cons of the o-ring but I do like specific information so that people can make choices. Is the o-ring in question on this catalog page (from the Filling Station)? If the link does not work, the part number is FS-4356 at The Filling Station (which has a catalog that works oddly at best in some web browsers). | | | | | Joined: Jan 2007 Posts: 36 Apprentice | | Apprentice Joined: Jan 2007 Posts: 36 | Good options for sure. Thanks guys, I will let you know down the road which one was the choice. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That could be the correct one, but what I would do is take the bell that slips on the end of the torque tube and the two flat rings at the back of the bell that are inside the hand tightened screw on ring and go to the "O" ring store, find the right size and buy it. According to The Filling Station, the price is $.75. Another thought would be to call The Filling Station and ask there "O" ring will work on your particular drive line. What ever you do, the point is that IT WILL NOT LEAK with a rubber "O" ring. It's easy enough to either find one locally or call and order one. You have to take the assembly apart either way. I would fix the problem so you don't have a problem anymore. Joe
