| | | Forums66 Topics128,170 Posts1,057,033 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Rochester B carb: a PO cut the choke suction tube about 1 1/2 inches from the carb. Now, it turns, but I can't remove it. PB blaster is currently soaking. I'm assuming the brute force method is a bad idea...any suggestions? Thanks | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Rochester B carb: a PO cut the choke suction tube about 1 1/2 inches from the carb. Are you referring to tube that should run from the carb to the vacuum advance unit on the distributor? Or, are you referring to the choke heater tube used on an automatic choke?
Now, it turns, but I can't remove it. What is "it" and "it" - the tube connected to the carb?
I'm assuming the brute force method is a bad idea... Where and how would you be applying brute force? To remove the tube from the carburetor?
If you are referring the remains of a vacuum line going into the carburetor, what type of fitting is between the tube and the carburetor? If you are referring to an automatic choke heater tube on a Rochester one-barrel carb, I think it just pulls off.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Is this the tube that warms up the choke themostaic spring? | | |
