4 members (klhansen, HandyAndy, Otto Skorzeny, Hush), 81 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#49476 08/25/2005 6:13 PM
Junior Member
Junior Member
OK,I finally got my 58 1/2 ton on the road with a new 350 chevy engine. Still have original tranny and 3 on the tree and original rear end with no clue of its gear ratio, It is turning some major RPM'S going 40-45 MPH. does anyone know a good or compatible swap on the rear end that wouldn't require a lot of modification? any help would be appreciated. Thanks
#49477 08/25/2005 6:20 PM
i'm sure not an expert but there are a lot of them on this website that will chime in here pretty quick but while you are waiting why don't you try the search mode. there is a ton of discussion on this type of swap. good luck.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#49478 08/25/2005 6:51 PM
3;55 gears in the rear.
dan-pa
#49479 08/25/2005 9:16 PM
Riding in the Passing Lane
The after market gears for the 55-59 are 3.38. They make a good setup because you don,t have to modify everything like when you change to a later rear end. They are expensive though. Also the 5speed o-drive trany ispretty easy to install. Get both & you can idle down the highway.
1972 Chevy c10 Cheyenne Super
#49480 08/25/2005 10:03 PM
if you've got stock gears they're 3.90, but you might have 4.10 which were what was used w/ overdrive for some reason - as Wrench sez the 3.38 would help lots, and there are a number of OD possibilities
#49481 08/26/2005 12:29 AM
i have a 54/ 235 and a nova 2.73 and 5 speed and mine motors just fine even in 5th. i live in flat land, some hills but not big and it does alright. 2000 at 60. about 1200 at 35 mph. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
