| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | This is on my '70 C10. Both low meams work but I have no high beams. I changed the dimmer switch thinking that was the problem but it wasn't.
Is there a way to check the headlights to see if the high beam is burnt out? Hate to replace the lights and maybe still have the same problem.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get a test light & see if you have current at the headlight socket when they are turned on. Check the connector on the dimmer switch they are sbject to corrosion. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | don't forget to check for power and ground at the headlamp, jump power and ground directly to the headlamp to see if it's burnt out.... | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | don't forget to check for power and ground at the headlamp,
if there was a bad ground he wouldn't have low beams !! maybe as mentioned an open circuit for high beams probably close to the foot switch.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2007 Posts: 81 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 81 | I bet this is all related to his lights flickering mentioned in another post. I bet the headlight switch is bad, I think power for all the lights runs through that switch.
52 Chevy 3100 5 Window, LS Swap, 4spd Auto, Vintage Air AC / Heat, CPP Power Front Disc Brake Conversion with bearing upgrade, Power Steering Conversion, LED Tail Lights
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | it's the headlight switch if the wire terminal is corroded or a broken wire there. if the lows work and not both the highs, then it's the dimmer or wires . a stock harness (which we don't know what he has) has the same fuse for all.
unless he has what some of us have a separate circuit for each. i run two relays ... one for each Lo/Hi beam it's easy to trouble shoot.
