4 members (Otto Skorzeny, Aggie49, baldeagle, Cosmo), 89 guests, and 5 robots.
Topics128,021
Posts1,055,348
Members48,420
#494379 01/17/2009 3:49 PM
Leo
Offline
Moderator
Moderator
I'm not the first person who has trouble getting the fan to fit between the engine balancer and the rad. I have a 261 with a short waterpump. I have 2 1/2 inches between the waterpump mounting face and the rad. I have a 6 blade x 18" fan with a 1" arbor. The blades angle back and hit the balancer by 1/4", maybe 3/8". I still have good clearance ahead of the fan. Does the correct 4 blade x 18" fan angle back? My shop manual shows that it doesn't. I'm not sure where the 6 blade came from, it was on the truck when I got it, are they used on A/C trucks or cars?
Leo #494446 01/17/2009 7:08 PM
all of that is why i prefer the adapter plate to raise
the water pump up to where it should be the short shaft pump does not address that issue.
philip t #494447 01/17/2009 7:20 PM
Before I put in the adapter plate and pump (last summer), I used a 6-blade fan (bought in 1972 from NAPA) that was small enough diameter that it did not hit anything.
tclederman #494491 01/17/2009 10:35 PM
Ex Hall Monitor
Ex Hall Monitor
I don't have that engine & am not familiar with the issue but will the fan clear if you turn it around? The blade pitch will be the same (pulling air instead of pushing as many people think happens when you turn the blade around) but should angle forward, away from the balancer, instead of back. If you have enough clearance in front it might work????? ohwell
Tiny #494514 01/17/2009 11:28 PM
Leo
Offline
Moderator
Moderator
Tiny, tried that, it's symmetrical, doesn't work.
Leo #494557 01/18/2009 1:26 AM
Some folks use a plastic fan and trim it to size. I think Tony "Truckedup" talked about that in a post.
1951 1 Ton Completed
truckernix #494594 01/18/2009 2:57 AM
Leo
Offline
Moderator
Moderator
Fred, that thought crossed my mind. how well balanced should the fan be? One other issue, the rad slopes back a bit toward the engine at the top, my front clearance is a bit less.
Leo #494608 01/18/2009 3:31 AM
I think that there was also a discussion about the plastic fan flexing, I guess towards the front as it pulls the air through. I would think that the plastic is lighter and thus easier to balance.
Do you have your front clip on yet? The inner and outer fenders will influence the angle of the radiator support.
Fred
truckernix #494710 01/18/2009 2:33 PM
2 Offline
Why not put a 14" electric pusher fan on the front of the radiator and be done with it?
