5 members (1955 1 Series, jmoore, Otto Skorzeny, JW51, papas52), 100 guests, and 3 robots.
Topics128,085
Posts1,056,329
Members48,442
I'm now working on the standard steering and ordering front end bits to replace the 50+ years old stuff. I'm also pulling the springs for re-work and while its all apart I might as well consider everything. No IFS money right now. Are there good quality up-graded tie rod ends (or any other bits) for the AD 48-54 3100 trucks?? If so what is the differences between those on the market? What else should I look at that may have worn out over the years that may cause problems & needs replacement? Which company(ies) sells them?
gooday
thanks
jim
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
Riding in the Passing Lane
Yes there are upgraded tie rod ends available. I just put them on my 55-II. I got them from either Chevy-Duty or LMC. I can,t remember which. I am close to both. The were a little onery to put on. You have to remove the stud from the steering arms. smile
1972 Chevy c10 Cheyenne Super
I am just north of KC about an hour or so... where is Chevy Duty located?
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
Go to your local parts store and ask for Moog part # ES29R and ES29L. These are the new ones you want. There are numerous web sites which show you how to replace your existing with these.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
olblu49
cause i have not heard of moog. i did a search
moog recall of suspension parts ???????????
this may NOT be the same thing but worth looking into....
http://www.recall-warnings.com/auto-content-17978.html
http://www.recall-warnings.com/auto-content-48128.html
Jim & Caroline
Junior Member
Junior Member
Jim, Moog is a pretty respectible hard parts line. I think they`re sold through NAPA. Try the guys at Riebes in Grass Valley, Or Colfax, they should be able to fix you up.
unless your the lead dog, the view never changes!
Chevy-Duty is near where I-29, I-635 & 9 high. come together on the north side of KC area. The shop I work out of is near there. Carquest caries the Moog line but those parts were discontinued the last time I tried to get some there. You might try them though sometimes these parts guys don,t know or don,t care.
I have some of those tie rod ends ES29 R+L new. $22 ea. [email protected]
I think it is the Brother's truck site that has an article on the upgrade that you are talking about. The newer style drag link does not go on the pre 53 models so you are in luck.
1951 1 Ton Completed
