9 members (Bizaircon, Youngin' Tut 59, klhansen, J Lucas, Hotrod Lincoln, 5 Window 9434, lumbersawyer, DougH6100, 1 invisible),
78
Mod | | | Forums66 Topics128,139 Posts1,056,762 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49404 08/23/2005 5:37 PM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | I'm now working on the standard steering and ordering front end bits to replace the 50+ years old stuff. I'm also pulling the springs for re-work and while its all apart I might as well consider everything. No IFS money right now. Are there good quality up-graded tie rod ends (or any other bits) for the AD 48-54 3100 trucks?? If so what is the differences between those on the market? What else should I look at that may have worn out over the years that may cause problems & needs replacement? Which company(ies) sells them? gooday thanks jim
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#49405 08/23/2005 10:24 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes there are upgraded tie rod ends available. I just put them on my 55-II. I got them from either Chevy-Duty or LMC. I can,t remember which. I am close to both. The were a little onery to put on. You have to remove the stud from the steering arms.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#49406 08/24/2005 12:08 AM | Joined: Aug 2005 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 81 | I am just north of KC about an hour or so... where is Chevy Duty located?
Boogity, Boogity, Boogity Let's go racin boys. Drive fast, turn left. GO #20.
Real trucks where bowties.
#49407 08/24/2005 3:04 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Go to your local parts store and ask for Moog part # ES29R and ES29L. These are the new ones you want. There are numerous web sites which show you how to replace your existing with these. Bill | | |
#49408 08/24/2005 3:06 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | olblu49 cause i have not heard of moog. i did a search moog recall of suspension parts ??????????? this may NOT be the same thing but worth looking into.... http://www.recall-warnings.com/auto-content-17978.html http://www.recall-warnings.com/auto-content-48128.html
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#49409 08/24/2005 3:31 PM | Joined: Apr 2005 Posts: 16 Junior Member | | Junior Member Joined: Apr 2005 Posts: 16 | Jim, Moog is a pretty respectible hard parts line. I think they`re sold through NAPA. Try the guys at Riebes in Grass Valley, Or Colfax, they should be able to fix you up.
unless your the lead dog, the view never changes!
#49410 08/24/2005 10:44 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Chevy-Duty is near where I-29, I-635 & 9 high. come together on the north side of KC area. The shop I work out of is near there. Carquest caries the Moog line but those parts were discontinued the last time I tried to get some there. You might try them though sometimes these parts guys don,t know or don,t care. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#49411 08/25/2005 1:32 AM | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I have some of those tie rod ends ES29 R+L new. $22 ea. [email protected] | | |
#49412 08/25/2005 2:14 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think it is the Brother's truck site that has an article on the upgrade that you are talking about. The newer style drag link does not go on the pre 53 models so you are in luck. | | |
