Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#49396 08/22/2005 9:25 PM
Hi everyone, was wondering if anyone has any good feedback on some ideas I have. My truck is a 65 4wd Bowtie (Chevy) -- I currently have 2 parts trucks in my inventory... both are 79's one is 2wd (hi po 350) but complete rust all over body --- other is 4wd currently using it to haul wood for the winter...
My thinking is that I can swap several parts of these trucks over the 65 such as moving gas tank to between the frame- obviously the 350 hi performance engine and maybe some axle swaps possible- considering using the a/c unit if time allows... does anyone know how much other stuff off the 79's that i can swap? Right now I am not concerned about keeping the 65 stock so any help is appreciated. thanks
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
#49397 08/22/2005 10:28 PM
Welcome! I used a 1980 C10 to build my 64, used engine, trans, steering box & brake booster very easily. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#49398 08/23/2005 1:51 AM
Z
Z Offline
the front suspension and steering will mostly bolt in.
#49399 08/24/2005 12:01 AM
Thanks for the info guys that should help out a bunch. Is it pretty easy to convert the steering and suspension? Or probably need to expect a few small mods? Have you seen any swaps where the gas tank was moved to the frame and if so is that fairly easy to do? My guess is it would be easy to do as long as brackets and fuel lines are set properly.
