| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | Thanks to you guys I know what type of engine I have.Its a 235 block from 1954 with the cast #s of 3835911.The heads are from a 1953 235 with the cast #s of 3701887.I am new to these engines I don't know much about them.Is it werth rebuilding.Also I didn't mention that the truck it came from was in a garage fire.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy air chevy, that engine is a little rare and actually very desirable. It is a full pressure lubed engine, that was produced for two years or less, they have the high mount water pump, and are easily swapped into older vehicles, so yes keep it or sell it. | | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | Thank You 3B...That is very good to hear.I am gonna save up the money to get it rebuilt.Put it in my 47 truck .Thank You again...
| | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | what type of vehicle did this engine come from. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That block code is supposedly from a Corvette block sold after after 16 October 1953 (used in Corvettes from late 1953 into 1955). The head code is supposedly not for a Corvette head but it is a 1953 code (most likely it has two bolts holding the valve cover to the head). Is there a serial number (code) pressed into the ledge in the block, just to the rear of where the distributor enters the block? This would help to confirm the original use/year of the block. If this is a Corvette block, it might be of great interest to anyone restoring a 1953-55 Corvette. Locations of codes are shown on this web page. | | | | | Joined: Jan 2009 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 42 | the codes i see are - con1 & c124. | | |
