0 members (),
67
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Just wondering, is this a new intake? Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | hey 6,
yes this is "brand new in the box". auction bought from an online parts supplier.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | i would like to find a heat plate for mine 292 4 brl but those people will not talk to you ,guess i will have to make one . | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I don't recall the underside of mine but the casting was a little rough in that it had extra flashing around the bolt holes where the intake meets the exhaust. | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | check exeter auto. talked w/ them the other day and they were very helpful. http://www.exeterautosupply.com/
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ed, here is a picture of my 2 x 1 offenhauser intake. I purchased it from jim carter. 2 x 1 offenhauser intake 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Well; the next problem you are going to have is those round holes where the aluminum was cast will leak. They're the ones with the steel plugs spotted into them. You can see them in Tim's picture. Mine leaked like a sieve when I put water through it. I had mine welded shut. I assume that they'd leak exhaust too, just not make such a mess. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | For the heat plate, have you considered Tom Langdon and his Stovebolt Engine company? You can find him in the links section. His heat plate sells for about $35, give or take. I plan to use one on my Offy 4bbl intake on a 250 L6.
Best wishes,
Les | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Jerry, you are looking at aluminum slugs i made.I had my welder weld them up solid.I set the intake up for water heat,if i decide to ever go that route.The picture is before i had them welded in place.
Ed, my intake did have some jagged edges from casting.I used a small file to clean them up. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | I bought my Offy dual from Tom Langdon. I looked at your pics and don't see any problem with the "innards" but you need to make sure that the sealing flange is smooth and good. I bought one of these and have documented the installation as well as the mating of the Fenton headers on the engine rebuild album on the website below. Hope the pics help you! | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | thanks all. did not expect something as rough in a brand new state. once you get things home i guess they always look a little different.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That really surprises me. I bought an Offy about five years ago and it is very nice. I have been told that they will leak water if using water heat, but I think Offy's were intended to be used with exhaust heat. That's why the bottom of the intake is made to match up with a stock exhaust manifold or Fenton headers with a heat box cast into them. Well, I hope you can make it work for you, Ed. Good luck! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | hey tim,
do you have a direct link to a picture of the aluminum slugs you had welded in the offy? i was looking at your pics and the only one i saw was the steel plugs on the offy bottom, just like i have now. thanks
big ed
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ed, I will link some pictures later today. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a suggestion.....although many trucks are running water heat, I've found that using exhaust heat (if your running Fenton Headers) is a viable option. Using Langdon's heat plate and some compression fittings makes plumbing in the exhaust heat a much simpler install and you don't have to make any modifications to the heat circuit of the Offy intake. Secondly, you eliminate the potential for water leaks which could leave you stranded beside the road.
I've got nearly 8000 miles on my 235 engine and haven't had any issues with the exhaust heat. The pressure differential created by the firing order of the 235 DOES provide rapid heat transfer. I have pictures of the install in my Webshots albums. Check it out as you may agree that it is a proven viable option.
Dave | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I don't think you can call it a "bad" intake as the hand work that's always required with castings has merely been overlooked. A cylindrical carbide burr in a die grinder will fix it in no time. I agree that what you purchased was designed for exhaust heat but can be made to use with coolant if properly modified. To me the whole point is the quick heat exhaust provides.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I have a question about the exhaust heat setup. I understand that there is pressure differential from one header to the other but it seems that it would pulse the gas back and forth unless there is a check valve to create one-way flow. I've never worked on something like this but I plan to set up my 250 this way and I'd like to understand it better.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | In my opinion, the lesson regarding exhaust to be learned is in the answer to this comment. Originally, Fenton headers were offered with what some call a "heat box" on the rear header. This "box" had the same configuration on the top of it as the stock exhaust manifold and bolted to the bottom of the intake. This "heat box" was nothing more than an open passage way from the rear header into the box where the intake attaches, keeping continious heat to the intake. Later, because of the configuration of the 216 versus the 235 intake, Fenton went to the more common header set without the heat box and developed the plugs in the headers with the two tubes that attach to each header and run to a plate on the bottom of the intake, suppling heat to the intake. In so doing, the exhaust is "shared" between the two headers, or between the two sides. Here is where the equalization of the exhaust from each side works to together. It's not so much the lack of a one way flow as much as just the equalization of the exhaust from side to side to creat constant a heat source. It seems to work for a heat supply, but I agree, it doesn't seem like an equal flow would take place. I would suggest a plumbing pipe nipple pointing down on one exhaust pipe and above it another plumbing pipe nipple pointing up. Take the exhaust from the one pointing down, to a plate on the bottom of the intake and send it back out the other pipe to the nipple pointing up to create a circular motion of the exhaust to the heat plate. This would do more to move the heat and it would avoid the equalization process or the build up of any pressure between each side of the exhaust. I used this method on my truck for awhile and it seemed to work well. I now have a heat box rear header and, frankly, I'm not sure I could claim it works as well as the circulating set up. It heats fine, but it seems to take longer. Finally, mixing the sides, or the front headers and the back header, by use of the tubes from each header does another thing.....something I do not like. I destroys the "rap-rap" sound of the Chevrolet six, the sound I originally fell in love with many years ago. Obviously, this means that method is not even a consideration.....at least for me. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ed, here is the link to the pictures you requested. I welded mine up,just in case i want to run water heat to them. The exhaust heat seems to work just fine on my engine. aluminum slugs I did machine the fenton headers to mate with the offenhauser intake. 49geezer has some really nice pictures of how he did his. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A bit of correction, it's not so much as the difference between 216 and 325, but more the difference between the Chevy engine and the GMC. All current production Fentons are mad without the heat riser on the rear header so that the same casting can be used on either engine. Otherwise, there would have to be 2 different castings for the rear header to make up for the length difference. On a side note, I recently put exhaust heat on my Offy/Fenton combo (fabbed it myself) and notice no difference in how it sounds. But then again, mine doesn't have the "rap-rap-rap" sound, it sounds more like a cammed up Smallblock.
Bill Burmeister | | | | | Joined: May 2005 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 45 | BigEd I have some pictures of what it takes to replace those steel plugs with some aluminum slugs at http://community.webshots.com/user/OldFartEdHope this may help. Old Fart Ed (another Ed) | | |
