3 members (IHPWR, Otto Skorzeny, WICruiser), 85 guests, and 1 robot.
Topics128,029
Posts1,055,417
Members48,422
#493633 01/15/2009 8:14 PM
I'm planning on building an early 235 with the tall side cover (41-48) but I'm gonna "hop it up". Anyway, I was wondering what heads from different engines I could use and which might be the best?...The original head? or maybe a later one. Which heads will fit my 1947 235? Looking for help.
Craig
1953 3100 | 1958 3/4-ton NAPCO
graydon #493649 01/15/2009 9:08 PM
1950-53 216 head can be used, it has larger exhaust valves.
My Blog
Pre '68 Dave #493700 01/15/2009 10:47 PM
Be sure to do a VERY precise buildup on the lower end. Babbit bearings and high speed aren't necessarily a problem, but a low-pressure splasher engine will be terribly unforgiving of any mistakes in getting the rods lubricated!
Hotrod Lincoln #493723 01/15/2009 11:33 PM
Hopefully if all goes as planned I'm gonna have it converted to insert bearings and full pressure oil. I wanted the 235 for the extra cubes but I have a Nicson side cover I wanted to use. I also have some old Barker high lift rocker arms, Mallory dist., and some other goodies. I'm just looking for the best head to put on it. Thanks for the input guys.
