1 members (Stovebolt48),
73
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 84 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 84 | I'm planning on building an early 235 with the tall side cover (41-48) but I'm gonna "hop it up". Anyway, I was wondering what heads from different engines I could use and which might be the best?...The original head? or maybe a later one. Which heads will fit my 1947 235? Looking for help.
Craig
1953 3100 | 1958 3/4-ton NAPCO
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1950-53 216 head can be used, it has larger exhaust valves.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Be sure to do a VERY precise buildup on the lower end. Babbit bearings and high speed aren't necessarily a problem, but a low-pressure splasher engine will be terribly unforgiving of any mistakes in getting the rods lubricated! Jerry
| | | | | Joined: Sep 2007 Posts: 84 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 84 | Hopefully if all goes as planned I'm gonna have it converted to insert bearings and full pressure oil. I wanted the 235 for the extra cubes but I have a Nicson side cover I wanted to use. I also have some old Barker high lift rocker arms, Mallory dist., and some other goodies. I'm just looking for the best head to put on it. Thanks for the input guys.
