3 members (55shaker, Greg_H, 1 invisible),
106
Mod | | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | ok so im a computer idiot i will try one more time then i will seek help my web space | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i dont get it my web space | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | | | | | | Joined: Feb 2002 Posts: 2,898 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,898 | That is a sharp looking truck.
-W | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | thanks its been a lot of work the body work is far from perfect but i did it all myself the mechanics on the other hand are more my strong suit the engine is a 60 model 235 i added a hei from a 250 and langdons holly webber kit. it sure runs good i cant wait to drive it. the headlights and hood will go on this weekend then i need to tie up the loose ends. philip | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | Looking good!!!
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Way ta go Phil. Looks great ! | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | I'm jealous, Looks great! I cant wait to get started on mine. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Pretty cool pictures. On my computer I had to open and back click but it was well worth looking. What did you paint the frame with? What about the sound deadening material? Is it a generic material from a parts store? My truck had a felt pad in it, but it was a moisture holder if you ask me. Does that dog in the picture play the harmonica? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | the frame is painted with acrylic enamel the paint store put a paste in to make it semi gloss. i used the foil covered bubble wrap stuff from lowes to insulate the cab i also put the insulated firewall cover from jim carters. the fire wall cover is great but a real bear to install. the blue heelers name is jake he runs things around here were just here to feed him. philip | | | | | Joined: Dec 2008 Posts: 23 Apprentice | | Apprentice Joined: Dec 2008 Posts: 23 | That is a FINE looking truck!! I am working my 46 1.5 ton and wasnt sure were to find the tires and a motor to fit the truck. Any information you can pass along would be greatly appreciated. Hope you'll post a video of the the truck running and driving.
EMS is my life. But I have found my TRUE PASSION OLD TRUCKS...
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | im going to buy two front tires for now. my local truck tractor tire dealer can get them. you can also order them from an oriental company called simex but i at least want an American name on mine. i put a 1960 235 in this truck i found it in a junk yard for 100.00 with the trans. it cost me 1700.00 to rebuild it with new pistons bored crank ground head done and new cam. these motors arent that hard to find you just do not find them in the big salvage yards that deal in late models. you find them in junk yards or from someone that has one. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | philip, you truck is awesome. very nice.
just curious on these big trucks, does someone make the hood, fenders, windows, etc, like they do for the smaller 1/2 ton trucks ?
have fun.
leonard | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i think the hood and windows are the same as the 1/2 ton tho only real difference in the cab is the fenders and running boards. the cab is not bigger it just sits on a higher chassis. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks for the info. i was just curious.
leonard | | | | | Joined: Dec 2008 Posts: 23 Apprentice | | Apprentice Joined: Dec 2008 Posts: 23 | Thank you philip t. Thats helps alot.
