Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (KingG, baldeagle, Gdads51, Hotrod Lincoln), 44 guests, and 1 robot.
Topics128,007
Posts1,055,281
Members48,418
#493429 01/15/2009 4:40 AM
What size wire should I use going from my battery to the alternator? This in regard to my 216 generator to alternator setup.
Funton #493436 01/15/2009 4:54 AM
At least 10 guage.
Bill Burmeister
LONGBOX55 #493448 01/15/2009 5:36 AM
Funton,
I remember a few previous posts...are you going to tag the alternator output into the existing BATT feed to/through your stock ammeter?
If you do, follow Bill's advice and make that new wire 10 gauge from alternator output to ammeter.
Stuart
atomarc #494612 01/18/2009 3:40 AM
Think about fusing it if it runs into the cab. My stock alt only puts out about 35-40 amps, I put a 30 amp fuse on it two years ago, haven't had to replace it yet......except for the time I put the amp meter back in with the batt cable on. I like fuses, as long as I keep extras. It only takes once to burn one down
64 & 66 GMC long fleetside 4x4
Cartwright, OK
Fireballv8 #494621 01/18/2009 4:04 AM
#8
Jim & Caroline
