| | | Forums66 Topics128,005 Posts1,055,266 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | What size wire should I use going from my battery to the alternator? This in regard to my 216 generator to alternator setup.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Funton,
I remember a few previous posts...are you going to tag the alternator output into the existing BATT feed to/through your stock ammeter?
If you do, follow Bill's advice and make that new wire 10 gauge from alternator output to ammeter.
Stuart | | | | | Joined: Aug 2006 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 112 | Think about fusing it if it runs into the cab. My stock alt only puts out about 35-40 amps, I put a 30 amp fuse on it two years ago, haven't had to replace it yet......except for the time I put the amp meter back in with the batt cable on. I like fuses, as long as I keep extras. It only takes once to burn one down
64 & 66 GMC long fleetside 4x4 Cartwright, OK
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
