1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 49 New Guy | | New Guy Joined: Nov 2008 Posts: 49 | I have a 1940 1/2 ton chevy,I have read that the rear end from a 4 wheel drive blazer will work best, Is the rear end from an S 10 4 wheel drive the same? I have located an s 10 4 wheel that has all the other components I may use ..brakes, column etc. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | By Blzer, do you mean the full size K5, or the S Blazer? I beleive the K5 axle will be too wide, but will keep the 6 lug wheels. The S Blazers are the same as their pickup relatives, and are 5 lug. If you go the S truck/Blazer route, look for a '98-'04 4 door or ZR 2 truck. They have 4 wheel disk brakes, easy upgrade. Also, the ZR 2 has a modified full size truck axle, which is stronger than the std S truck axle.
Bill Burmeister | | | | | Joined: Nov 2008 Posts: 49 New Guy | | New Guy Joined: Nov 2008 Posts: 49 | I was referring to the s blazer, Thanks for the info. The s 10 pick up I am looking at is a 92 pickup 4 wheel drive, does it have disk on the rear? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No, '97 or '98 was the first year for that, and then only on certain models, mainly ZR 2 pickups/2 door Blazers, and also on 2 and 4 wheel drive 4 door Blazers. I have seen a couple of 2 wd extended cab pickups with them also.
