| | | Forums66 Topics128,263 Posts1,058,348 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 54 | Has anyone used the rustoleum hammered paint for their engine bay and firewall? How would this hold up to oil, gas, etc. compared to Eastwood's Chasis Black paints?
Anyone tested this and can give their thopughts?
Eric | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | I have. Love the stuff. Just make sure it's clean. Use Ace Hardware BBQ paint as a primer (Heat). Make sure you cover anything so you dont' get overspray. Use Alum foil to mask off hard to mask places and items. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I never had any good luck with large areas. I've used it on heaters and radio's and they came out fine. But, it worked with Project Helen, so give it a go. If it doesn't come out, just repaint. Cecil........ | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | It works great for small items like radios. If you are fussy about it, you will find that the hammered affect varies with how it is applied. You can only keep a certain size of area "wet" at one time to allow it to flow together. On the other hand the bumpy texture tends to hide imperfections. I think the finish was originally intended to look good but absorb some rough service. I have seen lab equipment with a similar finish. | | |
