0 members (), 159 guests, and 2 robots.
Topics128,260
Posts1,058,342
Members48,485
Has anyone used the rustoleum hammered paint for their engine bay and firewall? How would this hold up to oil, gas, etc. compared to Eastwood's Chasis Black paints?
Anyone tested this and can give their thopughts?
Eric
I have. Love the stuff. Just make sure it's clean. Use Ace Hardware BBQ paint as a primer (Heat). Make sure you cover anything so you dont' get overspray. Use Alum foil to mask off hard to mask places and items.
I never had any good luck with large areas. I've used it on heaters and radio's and they came out fine. But, it worked with Project Helen, so give it a go. If it doesn't come out, just repaint. Cecil........
It works great for small items like radios. If you are fussy about it, you will find that the hammered affect varies with how it is applied. You can only keep a certain size of area "wet" at one time to allow it to flow together. On the other hand the bumpy texture tends to hide imperfections. I think the finish was originally intended to look good but absorb some rough service. I have seen lab equipment with a similar finish.
1951 1 Ton Completed
