0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49295 08/19/2005 11:51 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | my 63 c-10 has a later model steering wheel. its chevy and possibly from a caprice. the drivetrain is... anyways im trying to remove it and running into a lot of difficulties. i pulled the cover and removed the steering nut but and some star screws and the wheel came off but the adapter didnt come off. its hard to explain the look. it curves out and almost looks like a flower thet the steering wheel attaches too. any one know what this is from and how to remove it? i can post a picture if needed... thanks in advance | | |
#49296 08/20/2005 12:14 AM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | | | |
#49297 08/20/2005 12:15 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | | | |
#49298 08/20/2005 12:19 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | well i dont know what it is but it has holes for a puller so it will come off.you will need a steering wheel puller use the 2 threaded holes for the puller bolts and it should pop right off then you can put a stock wheel back on.you can pick up a cheap puller at Oriellys for under $20 | | |
#49299 08/20/2005 3:20 AM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | sounds good. thanks for the reply. i'll give that a shot | | |
#49300 08/21/2005 5:14 PM | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | worked like a charm! Thanks | | |
