1 members (Bill Hanlon),
48
Mod | | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 8 New Guy | | New Guy Joined: Mar 2008 Posts: 8 | I have a 51 1/2 ton that has another vehicles column. Column is too fat for the spot where its suppose to go and was just bolted to the side. I was givin a column from a friend of mine that had an extra one that came with his 51. Column has no shifter, is there something i can adapt to it so i could get it to work with my automatic trans? thanks very much in advanced  | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | are you going with column shift or floor shift ? you might try late 60's early 70's chevelle ,gto ,leman's units they are relatively small . | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | cruisinchevy51: I'm not exactly sure what you are wanting to accomplish. I think you want an original column but your wanting to know if you can find something to adapt an automatic shift linkage to it.....I do not know of any that will work perhaps someone will yet step forward.
As a side note I know of guys using a colum out of an 80's(?) van because it has the turn signal, tilt, and the switch is NOT on the colums so they can still use the dash switch.
For me I have a steering wheel/column out of a 68 pickup that is trim (small), turn signal, and has the automatic lever on it, I can keep my dash switch. I'm PLANNING on trying to use it as someone here on the bolt did some time ago. When I got the steering colunm I also got the automatic linkage. I believe that with a small amount of modification I can use all the linkage. I'm just hoping the master cyl won't be in the way when I need to weld the bracket to the side of the chassis to make it work.
So, Maybe something I've said has give you some idea's or hope. I'm not sure what my situation will end up being but when I'm through hopefully I can help future Bolters!!! I'm sure their is a Hot Rod Shop out there somewhere that has, or can help get me, and you, get to where we want to be. | | |
