3 members (Peggy M, Otto Skorzeny, 49nut), 87 guests, and 4 robots.
Topics128,087
Posts1,056,337
Members48,442
I have a 52 chevy 1/2 ton, trying to figure out the correct way to install the weatherstripping around the doors, I bought the good seals from Chevy duty, they have a longer leading edge on one side, that I assume protrudes into the cab opening once installed ? But having trouble shutting the doors completely once there. Doors shut fine and flush before with the old seals.
so any pictures out there I can see to determine which way they go ?
thanks all
The 90° corner of the seal is glued on both legs into the corner of the door frame, the acute angle or more pointed corner is directly oposite to the 90° corner and pointing outword. Here's a shot of the drivers side seal, and these were from Chevy Duty also last year:
http://rides.webshots.com/photo/2535155990098611668OIGypn
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks Denny, yep I put mine on wrong.
And give those new seals a few weeks to "set" if you have problems with the doors closing all the way. I had trouble getting mine to close flush, or real close to flush, at first. Kept the doors closed as far as possible for a few weeks with a few tweeks here and there and eventually they did come in.
Bob
Hello Denny, what about the bottom of the door where the metal strip holds a seal, I noticed my door seals were too long, and there is enough to do the bottom of the doors, but it appears it gones on differently ? does the long edge go under the strip ?
Just noticed your post Mobil, a picture is worth a thous...... well you know the rest, try this; http://rides.webshots.com/photo/2395785850098611668qDSomp
Should be one piece starting at the bottom about 10" from the front and going all the way round till the ends meet.
Denny G
Denny G
Sandwich, IL
Jim & Caroline
Many thanks guys.... I had no idea how to put the weatherstrip on my '49 Chevy until this thread.
Thanks.
Harrell Lee Sellers
Brookings, SD
P.S. Did you take the door off?
HS
Was doing a search on this because this is my next endeavor on my 53. Found that most pictures are not linked anymore, especially photobucket and webshots .
So I found these two links on you tube showing how to do this job. Got a few hours of research so hopefully this helps someone else in the future.
Steve
www.youtube.com/watch?v=Rc631QtdiC0 - link no longer valid
1947-55 1st series Chevy Pickup Door Weatherstrip Installation
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
