11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible), 116 guests, and 1 robot.
Topics128,124
Posts1,056,347
Members48,441
#49149 08/17/2005 2:37 AM
Do the 248,270, and 302 for GMC trucks use the same intake manifold. I need to replace a cracked one.
#49150 08/17/2005 3:22 AM
The 302 and 270H have larger intake ports than the standard 270 and smaller size engines.
Jason
#49151 08/17/2005 4:59 AM
Do you know the best way for a quick ID on these motors?
#49152 08/17/2005 6:10 PM
A quick way to ID the motor is to look at the serial number stamped on the boss behind the dist. The first 3 digits is the engine size.
A quick way to ID the heads is http://www.oldgmctrucks.com/photos/gmc_heads.jpg
