1 members (MikeE),
121
Mod | | | Forums66 Topics128,129 Posts1,056,360 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49149 08/17/2005 2:37 AM | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Do the 248,270, and 302 for GMC trucks use the same intake manifold. I need to replace a cracked one. | | |
#49150 08/17/2005 3:22 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | The 302 and 270H have larger intake ports than the standard 270 and smaller size engines.
Jason
#49151 08/17/2005 4:59 AM | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Do you know the best way for a quick ID on these motors? | | |
#49152 08/17/2005 6:10 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A quick way to ID the motor is to look at the serial number stamped on the boss behind the dist. The first 3 digits is the engine size. A quick way to ID the heads is http://www.oldgmctrucks.com/photos/gmc_heads.jpg | | |
