4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#491247 01/09/2009 12:21 AM
Does anyone know if the Steele windshield gasket is superior to the cheaper gaskets that some vendors are selling.
I have a gasket that I put the glass in today. (not Steele) It does not fit well in the lower outside corners. I am reluctant to try and install it, as I don't think it is going to be satisfactory.
1949 Chevy 6400
1931 Chevy Firetruck
Go with Steele.
I went with Steele. Pricey but exact.
Weeds
Weeds #491427 01/09/2009 11:49 AM
I got mine from LMC and it is the same as what you are stating bought not fitting well at the bottom outside corners.
I hoped after it was in the sun a while it would tighten up but it hasnt and now I have a puckerd gap at those 2 corners.
I plan to get a replacement from Steele.
Tim
1952 Chevy Shortbed
Photos in Photobucket
OK. Thanks guys. I will call Steele this morning.
1949 Chevy 6400
I've got a Steele gasket on my windshield, but I've got the corner pucker on one side, and a stubborn leak. My problem might be the installer - me.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
The problems at the lower corners are more likely to be the glass itself, I'm assuming a lot of you guys have used new glass.
If the glass radius is incorrect no seal ,no matter how good will correct this.
This seems to be a common problem on AD series aftermarket glass.
The seal needs the glass to be the correct shape to physically 'push' the rubber out to the bodywork.
I noticed this on mine and plan to cut my own screens to fit.
Jimmy1 has been experiencing the same problem on another post.
Just my 0.02c worth.
More pix on Flickr.
Thats a good point jockbolter50. I am going to hold the glass up to the opening today and see how it compares. I may be able to grind more radious on the corner.
1949 Chevy 6400
I've got a pucker on my truck, but no leaks. After the instal, it's important to put a sealer in-between the glass and gasket, and in-between the gasket and the pinch weld. I used some NOS sealer I had, but you can use the 3M stuff. It's in the 3M automotive chemicals catalogue, but it's in with the seam sealers. It's black butyl, never hardens, ever, and it's you friend. You just need to fill up the pucker with it as well, and then smooth it out. It helps if you use the fancy trim, because it takes your eye off of the corner.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I got the Steele gasket yesterday. Put the glass in it, and it fits great. No sign of a pucker in the corners.
1949 Chevy 6400
That's good news! Glad you got the problem solved. thumbs_up
More pix on Flickr.
