Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Ponchogl, 1955 1 Series, homer52), 113 guests, and 3 robots.
Topics128,283
Posts1,058,505
Members48,490
#49140 08/17/2005 1:30 AM
1 Offline
Does anyone know where I canfind a skematic or a diagam of the rocker arm assm. for a 1957 , 235 that is going into a '51 3100? The friend that is rebuilding it says he thinke something is missing in the center of the assm. where the two rods fit together, not the part that holds the two rods together , which is also part of the oiling system, but the parts on each side of this. Any help would be greatly appreciated , especially a diagram. Thankyou
Custom Title
Custom Title
Bump... I could use the same info...
49 Chevy 3600
65 Chevy K10
66 International 1300 dually 4x4
46 Ford 1/2 ton
76 Tucker Sno-Cat 1642
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Tab Offline
Someone with a 57, 235, take off the valve cover and send these guys a pic.
delete my account and pictures
Does this help? It's from a 1955 235, but should be exactly the same. Rocker assembly
I sent one of these guys the same thing, out of my shop manual..Steve
1 Offline
Thanks a million fellas. I printed it out and will run it out and see if this helps. If he is still confused I'll get back to you.
I have a 1957 235 with '848 head and the center looks just like Shipwright's link, with a small spring and spacer/shim on each side of the oil connector. The shim goes on the inside against the oiler like the pic.
However, the oil connector itself looks different. It does not return back to the head but is pinched off at the top so it will spray oil on top of the rocker assy.
Mike Barnes
1950 GMC 1-ton pickup
1 Offline
Yeh; I showed Shipwright's link to the friend who is rebuilding mine and as he had figured, we are missing the two small shims or washers and also the two springs. One spring and one shim on each side of the center oiler. Don't really know where we are going to get them. Can anyone help? Thanks
Patrick's builds a lot of engines..Maybe call them and see if they have some laying aroung..
520-836-1117
