5 members (Stovebolt48, Otto Skorzeny, Youngin' Tut 59, DadsFirstPickup, baldeagle), 65 guests, and 4 robots.
Topics128,180
Posts1,057,148
Members48,464
Is there an adaptor to hook up t-5 trans to a 1948 closed driveshaft and if so where can I find it.
Tschall
Not that I'm aware of, conversion to open drive is required. There is a kit available from Patricks to use a 4 speed Saginaw with the torque tube, however. But that trans isn't an overdrive.
Bill Burmeister
I think you will find that the T5 is longer than your existing trans which means that if there was an adaptor to your torque tube, the torque tube would be too long and need to be shortened.
It would be easier to get yourself the center pumpkin out of a 55 or later truck. It will bolt up to your orig. axel. Then you can go to an open drive line. This is thr route I took on my 46. It work very good. You will like the T5 thumbs_up
George
One thing... If you change to an open-drive-line pumpkin, you must either weld the spring perches on your axle, or change toe perches to fixed-type. Torque tubes rely on the hinge at the spring to keep the yube from bending as the suspension moves.
What years pig of work?
Tschall
'55-'62 truck. Passenger version will not work. Most of them will be the 3.90 gear, though there are 3.38 and 4.10s out there, too.
Bill Burmeister
