8 members (Forty9, Joe H, MickeyP, FAST55, 55shaker, 68ironhead, LAROKE, 1 invisible),
63
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 6 New Guy | | New Guy Joined: Jan 2009 Posts: 6 | Is there an adaptor to hook up t-5 trans to a 1948 closed driveshaft and if so where can I find it.
Tschall
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not that I'm aware of, conversion to open drive is required. There is a kit available from Patricks to use a 4 speed Saginaw with the torque tube, however. But that trans isn't an overdrive.
Bill Burmeister | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I think you will find that the T5 is longer than your existing trans which means that if there was an adaptor to your torque tube, the torque tube would be too long and need to be shortened. It would be easier to get yourself the center pumpkin out of a 55 or later truck. It will bolt up to your orig. axel. Then you can go to an open drive line. This is thr route I took on my 46. It work very good. You will like the T5 George | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | One thing... If you change to an open-drive-line pumpkin, you must either weld the spring perches on your axle, or change toe perches to fixed-type. Torque tubes rely on the hinge at the spring to keep the yube from bending as the suspension moves.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
Tschall
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '55-'62 truck. Passenger version will not work. Most of them will be the 3.90 gear, though there are 3.38 and 4.10s out there, too.
