8 members (KEVINSKI, Gdads51, TexasJim50, 1955 1 Series, Stovebolt48, 32Fordpuchoptop, lumbersawyer, 1 invisible),
59
0
Mod | | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49072 08/15/2005 3:08 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I have found a 250 c.i. motor out of a 1971 Nova. It was running when pulled for a built 350. I offered $100.00 for it. Sound about right? Thanks
#49073 08/15/2005 8:36 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If it's truly a good runner and doesn't burn oil. Not being able to see it run, I would have started at $50 and maybe gone to $100. A lot of it depends on how bad you want it and how hard it is for him to get rid of it. Sometimes you can find them for free, if the guy's wife is yelling at him to clean up the garage.
Fred 52 3600 69 C-10
#49074 08/16/2005 3:49 AM | Joined: Jan 2005 Posts: 35 Junior Member | | Junior Member Joined: Jan 2005 Posts: 35 | A good running 292 inline engine 1963 to 1972 is worth about $200.00
So a 230 or 250 that"s non integral head good running not too much smoke is worth about $50.00 to $100.00 be careful integral head ones are worth five bucks. Yeah you can get the garage clean up for free sometimes but it might be junk, and you just did a free clean up, better hear it run first.
1966 is the only year they had a steel crankshaft in the 250 engine unless I am wrong.? | | |
#49075 08/16/2005 5:21 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | i've seen prices for 292 long block's to be rebuilt as standard w/ rv type lift cam $1K, while other greasy motors on ebay that don't sell (because of shipping issues) for 50 bucks. if you think it's a good clean motor, clutch and bell housing. Comp 130, oil pr. 45+, vacuum 10+ and you want it , get it. have fun
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
