7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel),
94
Mod | | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | I was able to remove my old windshield glass with out breaking them and bought a pair of replacements from one of the large catalogs.The glass thickness is OK, but the size overall is larger than the ones I took out. Has anyone run into this problem? I don't know if I should try to install them as is or have them shaped to what I took out? Thanks Jimmy | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | There has been folks post here in the past that there new glass was to big and had to have it cut down. If your old glass fit well in the frame I would use it as templates and have the new cut to match & save yourself a bunch of headache. Tim | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Hi Jimmy, Tim is absolutely right. Some of the aftermarket glass is a very poor fit,especially at the bottom corners.
There has been a few discussions about this already. As Tim said,if you think the glass you took out was a good fit,have your local glass shop cut the new ones to match.
Even if the new ones did fit,chances are they will leak on account of the gasket not making proper contact with the body surfaces,and worse case scenario is you'll break them trying to fit them!
Good Luck
Jock. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | Thanks guys I took your advice and had the repops ground down to the right size. Next time If I'am lucky enough to get them out in one piece to use as a pattern I'll have a glass shop cut them. Repops/80$ dollars; Regrinding repops/70$ dollars. Living and learning, priceless!! | | |
