4 members (Shaffer's1950, cmayna, 2 invisible),
122
Mod | | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 128 | Finally had some time to get this designed.... It fits into the dash where the original speaker/ash tray went uses the same bolt holes. [IMG]http://img185.imageshack.us/img185/6751/48to53adtruckdashinsertnq9.th.jpg[/IMG]I tried hard not to have to touch the dash, but I'll need to knock the divider out between the speaker and ash tray opening. And a small radial notch for the big gage. I'll most likely leave the metal and just move it so the dash could be restored if desired. I could have more cut if folks were interested.
| | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | I like it, what size are the smaller gauges. Ive been wanting to make a similar item that would mount 4 2-1/16" gauges in that center section. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | About how much would one of these cost? Can one be made out of say plain steel so it can be painted? Price depending I may be interested as I would like to mount my 4 2-1/16" gauges in the center section but don't really want to have to make a panel to weld in and one that would screw in would be great. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | it wouldnt take much to make a die set to stamp these out of 18 gauge.
| | | | | Joined: Dec 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 128 | If you had the tooling which would be not cheap. OK for volume. | | |
