7 members (rfs56trk, Gray_Ghost, Wally / Montana, walter74, MRMEROTH11, David Bush, cmayna),
55
Mod | | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 15 New Guy | | New Guy Joined: Aug 2007 Posts: 15 | Hello all, My 50 steering gear box leaks the gear oil I install. My question is can I pack the gear box with wheel bearing grease? Does anyone sell an overhaul kit for these, pulling the colunm from the box looks like a bear! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Gear oil is too thin. Try searching all the forums on the words +penrite +cornhead Rebuild kits are available - maybe someone else knows if that kit contains seals (if they are necessary). | | | | | Joined: Aug 2007 Posts: 15 New Guy | | New Guy Joined: Aug 2007 Posts: 15 | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | .  LEARN to do SEARCHES http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z504823~P69.50~~~~S2JU18WUN875161316716c~Z5Z5Z5~Z5Z5Z50000014x https://www.stovebolt.com/ubbthread...e&topic=0&Search=true#Post422242Steering Box Lube A self-levelling, high viscosity lubricant containing non-corrosive extreme pressure additives. Ideal for veteran and vintage steering boxes. Not recommended for rack and pinion steering. 500 ml LUB009 $15 http://restorationstuff.com/Products/Penrite%20USA%20Online%20Brochure.pdf
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Where does one normally purchase cornhead grease? I've check my FLAPS, and they have no idea what it is. I get a blank stare at Tractor Supply, too. I can order a $2.99 10 oz. tube of it online, but I'd have to pay 10 bucks shipping. No way. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The column doesn't separate from the box. Actually, they're not too bad to overhaul, but there are a couple of special tools needed to get it apart. Namely, a spanner whrench to get the end plug out. I got mine from Snap-On, wasn't too expensive. I ended up making my won gaskets, suing a sheet of gasket material and the old ones as a pattern. The seal was simply micd and matched at the flaps. I think we went with one that was actuallya few thou smaller id so it would fit tighter to the shaft. If you tackle overhauling it yourself, either get a shop manual or print off the pages from Keith Hardys site to assist you.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 5,204 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,204 | Cornhead grease is available from any John Deere tractor dealer. Its got to be big tractors, lawn tractor dealers are clue less about combines! Joe | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Lithum based chassis lube works great too.
Drew
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I second what Joe H said. But don't go to the John Deere dealer that deals in construction equipment. I went to the store that deals in trucks,tractors,backhoes, and the like. He didn't know JD made cornhead grease. The other store had cases of the stuff, and I think I paid less than 3 bucks a tube. And one tube will be way more than enough for your needs. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The John Deere lawnmower/tractor/atv place near me had no problem getting it for the next day. Unbelievable at $2.99 a tube. I found I needed more than one tube to fill the box?
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | And if you use a rebuild kit, the sector shaft seal included is junk. GM still makes the original. | | |
