0 members (),
72
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | My grandpa, the original owner of the '65, came and picked it up today and took it to Statesboro, GA. He took it to the guy who restored it before my dad got the truck. He told the guy (Freddy) that he didnt think we put the right rings on, because there was no "lip" on the tops of the cylinder walls, and Freddy said, " I know they didn't put the right rings in because I remember boring this thing out when i restored it." The answer to all of my problems i should think. Still, it was my fault for not miking the bore... but lesson learned... | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | I hope that is the only thing wrong so that you can get back to driving that truck!  | | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | Is Freddy going to overhaul your engine? | | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | Grandpa said hes gonna mik the crank, change camshaft bearings, etc. is that an overhaul? | | | | | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | Yes, that sounds like an overhaul. I assume he is also going to rering it also. Sounds as though he is going to go through it pretty good. I think you will have a nice truck when it is finished. | | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | Just got more info. It was bored out .006" so thats exactly why it was smoking like hell! | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Better go back to math class! Try .060", NOT .006"! BTW, that's as far as that engine can be bored safely, so the next time it needs a ring job, you can make it into a boat anchor. Start saving your pennies for a 292. Jerry
| | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | but my grandpa said thousandths. maybe he said sixty thousandths. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | There's no such thing as a 6 thousandths overbore. The first oversize that's commonly done is a 30 thousandths (.030"), and the second overbore is usually 40 or sometimes 60. 250's are very bad about getting major wear on the #1 cylinder due to oddball coolant flow, so it's not uncommon to have to rebore to a big oversize, or to have to put a sleeve in the #1 cylinder to get it back to an acceptable size. If you put standard diameter rings in 60 over cylinders, they would almost fall in without using a piston ring compressor, and there would be no way to keep the engine from smoking. Sound familiar? Jerry
| | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | I faintly remember a tad bit of smoking... | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Jerry, it could be just worn .006" from to much honing, that could happened. I am betting, like you, that it has standard rings in .060" bore. I bet it turned over easy...... Joe | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Well, the guy who built it up the last time thinks they got the wrong rings.
"I know they didn't put the right rings in because I remember boring this thing out when I restored it."
Now that it's back under his supervision, I'll bet it comes out right this time! One of my mechanics did something very similar on a re-ring job on a Fiat 124 sports car, but only the oil rings were involved. The ring set he put in had the correct size comprsssion rings, .75 MM oversize, and standard oil rings! He didn't check the end gap on all the rings, which would have shown up the error. The engine used oil from day one, and by the time I got it back into the shop and tore it down, the guy had quit. No way to dock his pay for doing a half-arsed job! Jerry
