Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Hotrod Lincoln), 60 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#489817 01/04/2009 11:50 AM
I live in Indiana and have a 52 Chevy. Recently asked around at the alignment shops here in town what they would charge to re-aligne my truck. I want to rebuild the front end this spring and I know messing with this and replacing the worn parts will warrant an alignment. To my surprise, none of the shops can do an alignment on my truck. They say they don't know how?????? I have never done anything like this. Is this soemthing I can do in my garage? If so, how?
John Kinser
H Online: Content
You can adjust the caster by installing tapered shims between the axle and the springs. Toe is easy, just adjust the tie rod length. Camber changes require bending the axle, not a real problem, but it takes some special techniques and heavy jacks and chains, plus a big I-beam to anchor the axle down while you're jacking on it.
I'd suggest that you find a shop where they do alignment work on big trucks. Your little axle should present no problems at all to a shop that's accustomed to aligning a Freightliner or a Peterbilt. We bent a lot of I-beam axles at the family shop back in the 50's and 60's, but it's sort of a lost art now, along with the equipment to do the job.
here is a stovebolt tip on having an adjustable drag link /tie rod MOD. and modern ball joynts. also how to remove old tie rod round ball joynts
http://www.stovebolt.com/techtips/draglink_adjustable.html
http://www.stovebolt.com/techtips/tie_rod_replacement.html
hope it works for you.
Jim & Caroline
As Jerry described above, adjusting toe-in is relatively easy, whether or not you have an adjustment gauge.
front axle specifications for 48-51 (1952 should be the same)
