3 members (GRNHydra, MRMEROTH11, Wally / Montana), 68 guests, and 3 robots.
Topics128,066
Posts1,055,876
Members48,428
#489660 01/04/2009 2:23 AM
Hello all, My 50 steering gear box leaks the gear oil I install. My question is can I pack the gear box with wheel bearing grease? Does anyone sell an overhaul kit for these, pulling the colunm from the box looks like a bear!
Gear oil is too thin. Try searching all the forums on the words +penrite +cornhead
Rebuild kits are available - maybe someone else knows if that kit contains seals (if they are necessary).
Thanks for the link.
. computer_punch LEARN to do SEARCHES computerdeath computer_punch
ohwell
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z504823~P69.50~~~~S2JU18WUN875161316716c~Z5Z5Z5~Z5Z5Z50000014x
ohwell
https://www.stovebolt.com/ubbthread...e&topic=0&Search=true#Post422242
Steering Box Lube
A self-levelling, high viscosity lubricant containing non-corrosive extreme pressure
additives. Ideal for veteran and vintage steering boxes. Not recommended for
rack and pinion steering.
500 ml LUB009 $15 smile
http://restorationstuff.com/Products/Penrite%20USA%20Online%20Brochure.pdf
Jim & Caroline
Where does one normally purchase cornhead grease? I've check my FLAPS, and they have no idea what it is. I get a blank stare at Tractor Supply, too. I can order a $2.99 10 oz. tube of it online, but I'd have to pay 10 bucks shipping. No way.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
The column doesn't separate from the box. Actually, they're not too bad to overhaul, but there are a couple of special tools needed to get it apart. Namely, a spanner whrench to get the end plug out. I got mine from Snap-On, wasn't too expensive. I ended up making my won gaskets, suing a sheet of gasket material and the old ones as a pattern. The seal was simply micd and matched at the flaps. I think we went with one that was actuallya few thou smaller id so it would fit tighter to the shaft.
If you tackle overhauling it yourself, either get a shop manual or print off the pages from Keith Hardys site to assist you.
Bill Burmeister
Cornhead grease is available from any John Deere tractor dealer. Its got to be big tractors, lawn tractor dealers are clue less about combines! Joe
Lithum based chassis lube works great too.
Drew
I second what Joe H said. But don't go to the John Deere dealer that deals in construction equipment. I went to the store that deals in trucks,tractors,backhoes, and the like. He didn't know JD made cornhead grease. The other store had cases of the stuff, and I think I paid less than 3 bucks a tube. And one tube will be way more than enough for your needs.
The John Deere lawnmower/tractor/atv place near me had no problem getting it for the next day. Unbelievable at $2.99 a tube. I found I needed more than one tube to fill the box?
You Tube
And if you use a rebuild kit, the sector shaft seal included is junk. GM still makes the original.
