7 members (KEVINSKI, 52Carl, 1955 1 Series, UtahYork, Lightholder's Dad, BarryP, 1 invisible),
378
Mod | | | Forums66 Topics128,164 Posts1,057,080 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Has anyone tried the swap using the saginaw 4 speed from a Vega/ Monza that Patricks mentions in their catalog? If so, how is working for ya?
Hank | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I've seen a few guys here running that setup without problems. I was considering it myself until I found out it interferes with the power brake booster that I've already installed.
It's very unfortunate that an otherwise outstanding supplier like Patricks doesn't mention that up front. | | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | Woody and Hank,
I've installed this in my '54 Chevy with very little problems. It's been a great addition to my truck. It's a pretty straight forward install even for a novice like myself. I was a little overwhelmed when I got the kit from Patrick's and realized the transmission comes completely apart, I had never done anything like this. The instructions look a little vague and the pictures are terrible but, if you read the text and follow it you can do this swap with little trouble.
Woody, to answer your question about the power booster. I was able to move my power booster master cylinder back 12 inches and accommodate the opening for the reservoir under the seat. It works flawlessly. I also installed their dual exhaust which interfered with the proportioning valve but, I just relocated it to the inside of the frame rail.
I really enjoy the syrcro of 1st and having a 4 speed that is very traffic friendly while keeping the authenticity of the torque tube, this was the selling factor for this conversion. Had I not wanted to keep the torque tube I would have went with the T-5.
Long story short. It's worth the money but, dealing with Patrick's quite frankly is a pain in the Butt. They don't build the kits until they have enough orders and they keep none in stock. It took nine months to get my kit, and they charge your credit card immediately. They're nice people but their business skills lack a lot to be desired.
Would I go through this all again? Yes.
Cory | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | reading these couple of posts.....all of you are AD owners. was it necessary to shorten the tourque tube to install this tranny combo. i was told and have read that(i believe the meas. is correct) a 2.5" chop of the tube is required to get these in a 41-46. just wondering if it was the same for you. thanks and happy new year. big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | I did not have to shorten my shaft. It's a direct bolt in.
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Thanks Cory,
That's what I was looking for info. wise. I appreciate you sharing your experiences with Patricks.
Hank | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I wouldnt bash Patricks for getting enough orders prior to getting the kits made. There is most likely a minimum purchase level on parts or the price would go thru the roof for single piece purchases.
| | | | | Joined: Nov 2001 Posts: 217 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 217 | I'm not bashing them for waiting for them getting enough orders. I'm bashing them for charging my credit card and delivering the product 9 months later. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Cory, thanks for clearing up the interference issues. I wound up rebuilding my SM420 and keep the entire drivetrain (except the 235 engine) original, but that's more because my plan for the finished vehicle has changed... I want it to be close to the real thing, just safer and more reliable. I drove my truck around town with a transmission that had bad syncros and I couldn't downshift into second. That 216 would pull that truck up from like 15-20 mph in third gear without a shudder. For someone like me who grew up on 3-speeds with no syncro in first, driving a fully syncro 3-speed is a luxury. It just depends on your personal preference and I like my truck to be an old truck... with power disk brakes  | | | | | Joined: Nov 2001 Posts: 1,521 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,521 | I have a Saginaw 4 spd. in my 54 panel and its working great! But..I changed everything to open drive when i installed the Saginaw. I'm using a Hurst shifter with a "modified" shift lever to clear my bench seat. | | |
