7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby),
114
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | My 4 speed transmission needs rebuilt in my 1952 Chev Half ton. Where can I take it or ship it to have it Professionally ?????? rebuilt I want it to be like new, all new bearings, thrust washers,gaskets,anything that needs replaced. It still works but noisy and leaks at the gaskets etc. with 2000 members there has to be a few with an opinion of where to take or send for a quality restoration. Waiting for your input thanks Mike | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | National Transmission in Denver should have one. I sent them a core a while ago for that very transmission.
| | | | | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | I will give them a call thanks what are they paying you for a core ?? Mike | | |
#4895 02/23/2002 10:57 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | In IN, we have Power Train place that will rebuild any trans, rear or driveshafts from bigger trucks. I have asked about the 420 there myself. Local yard guy says the main gear clusters in 4spds can be $400 or more for new one. I would bet new bearings, seals, gaskets would be all you would need and you could do that yourself. Sometimes the first/reverse gears are bad as they are straight cut and no synchros and get "ground" when shifted into. I think Power Train is a national or at least Midwest company. Go to truck stops and pick-up some of the free books/catalogs in the Lounge area. They have shops and repair places listed in them from all over country.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
