5 members (NJC, FAST55, tclederman, Joe H, lumbersawyer), 64 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#489196 01/02/2009 8:59 PM
I am trying to find a stock tracking arm for my 62 C10. Is the adjustable model for lowering capable of extending to the original length? LMC does not seem to have anything execpt for 65-66. Thanks...
Trailing arms are all interchangeable from 1960 to 1972
Does anyone know how long they are? Thanks!!!
I don't need the trailing arms. I was asking about the tracking arm which goes from the frame to the rear end to keep it from twisting or leaning. LMC only has adjustables for dropped trucks and for 65-66. I assume it is a different length for the 62.
I could get an adjustable and modify it if it will nod extend to the correct length.
Anybody know the correct stock length for a 62?
I would think that if your 62 C10 had a Tracking Arm(Panhard Bar) originally it would be easy to see where it attached giving the required length. If it didn't then you would have to fab brackets anyway, so I would go with the modified type with threaded spherical heim joints.Check a 4 wheel drive aftermarket supplier. They would have all kinds of combinations for your truck.
Drew
I don't know the length of the arm you need, but I'm looking in the GM parts book, and 60-62 are by themselves -63-64 are also by themselves, and 65-72 are all the same. (In 1/2ton I'm talking.
Classic Performance Parts can probably help. They have three listed but have been extremely helpful answering questions over the phone. Their web is classicperform.com
