2 members (NorthCoast3800, DadsFirstPickup), 53 guests, and 3 robots.
Topics128,153
Posts1,056,849
Members48,456
has anyone used the p/s kit from CPP?
and does any other companys make a similar p/s kit for straight axle trucks?
would it be better to use one of the bolt on p/s boxes that will hook up to the drag link?
i dont want to lose my straight axle.
CPP has several listed. One uses a Saganaw gear box, one is a Toyota, the other uses a control valve and a ram. I have used the ram type which I did not like and have installed several Toyota conversions which are great. All of these kits are expensive and require modifications. Most of the aftermarket suppliers have the same kits. I didn't buy any of them from CPP.
Fred
I bought the cpp kit from Classic Parts of America for my 52. I got the basic kit, just the frame mount, hardware and steering arm and draglink. I bought a pump and box from the local u-pull-it yard for about $40 total. I also bought the pitman arm made for the conversion from Classic Parts. The basic kit was $95 and the pitman arm was $70. Classic Parts also gives 10% off to stovebolters. I didn't buy the complete kit because I have a inline 6 and the pump bracket included in the complete kit would be useless as they only work for a v8. I just designed my own brackets to mount the pump. It isn't a cheap conversion but it will be worth it.
Hey DL - welcome to the bolt.
I posed a similar question a while back. Here's the link .
This is what I plan on using when it comes time to upgrade. If you go this route let me know how it turns out. I'm very curious to know......
Good luck.
HC
57' Chevy 3100 Stepside
http://www.cardomain.com/ride/2630531
