7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP),
111
Mod | | | Forums66 Topics128,185 Posts1,057,203 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Hi Guys, I've got a Stock 1946 1/2 ton that I am considering doing some changes to. I eventually want to put a 235 inline six in place of the old babbit pounder 216. I have located an excellent 235 from a 1962 Chevy 1/2 ton donor. The eventual tranny will be a Saginaw cast iron 4 speed. My question is about the bell housing currently in the 1962 donor. It is for a hydraulic/slave cylinder style clutch with the clutch fork mechanism on the passenger side. Is this compatible with the Saginaw and /or is it desirable at all? Should I take the bell housing as well? Any replies are welcome. 46Possum | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Take the bellhousing, spare parts and future options are always good things.
Personally I would go for a proper mechanical linkage and skip the hydraulic one, mechanical gives less trouble and is simpler most of the time. So you probably want a normal left side fork bellhousing.
Grigg | | |
