2 members (stlcardinalsguy, Steveoreno), 85 guests, and 8 robots.
Topics128,187
Posts1,057,212
Members48,465
Hi Guys,
I've got a Stock 1946 1/2 ton that I am considering doing some changes to. I eventually want to put a 235 inline six in place of the old babbit pounder 216. I have located an excellent 235 from a 1962 Chevy 1/2 ton donor. The eventual tranny will be a Saginaw cast iron 4 speed. My question is about the bell housing currently in the 1962 donor. It is for a hydraulic/slave cylinder style clutch with the clutch fork mechanism on the passenger side. Is this compatible with the Saginaw and /or is it desirable at all? Should I take the bell housing as well?
Any replies are welcome.
46Possum
Take the bellhousing, spare parts and future options are always good things.
Personally I would go for a proper mechanical linkage and skip the hydraulic one, mechanical gives less trouble and is simpler most of the time.
So you probably want a normal left side fork bellhousing.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
